Hello Guest it is November 10, 2026, 01:54:21 AM
Author Topic: Internal error <SetUserDRO>  (Read 12239 times)
Offline geast
  •  51 51
« on: February 06, 2014, 02:24:15 AM »
A very strange error only in windows XP
I write a simple macro in windows XP
Dim  Y As Integer
Dim A  As Double
Y = 1000
A = 1234
aaa= GetUserDRO(1000)
SetUserDRO(Y,A)
and when i executed in windows vista everything is ok, but when in XP i have an error Internal error <SetUserDRO>.
Please check the attached pictures
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Internal error <SetUserDRO>
« Reply #1 on: February 06, 2014, 04:28:21 AM »
Works fine here under XP but usually this CB "internal error" is down to some subtle syntax error. According to VB syntax a procedure call shouldn't have () unless it's called via the CALL keyword. Sometimes it works out ok and sometimes it doesn't. You could try changing line 9 to:
SetUserDRO Y, A
or if you want the parentheses
Call SetUserDRO(Y, A)
Also it's always a good idea to assign explicit real numbers to real variables i.e.
A = 1234.0
Offline geast
  •  51 51
« Reply #2 on: February 06, 2014, 04:42:21 AM »
None worked, either the parenthesis nor the Call, or the 123.4
Any other ideas?
Offline stirling
  •  2,188 2,188
  • UK
« Reply #3 on: February 06, 2014, 04:47:26 AM »
try taking out the explicit typing of A and Y i.e. remove the two DIMs also remove the call to getUserDRO as it's not doing anything at the moment.
Offline geast
  •  51 51
« Reply #4 on: February 06, 2014, 05:02:32 AM »
No luck, i attach the pictures, as simple as it gets.
The mach version im using is R3.043.022.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: February 06, 2014, 05:13:31 AM »
Best I can suggest is you try a re-install of Mach - maybe ENABLE40.DLL got corrupted but that's clutching at straws. I'm on the same Mach version and XP.
Offline geast
  •  51 51
« Reply #6 on: February 06, 2014, 11:52:30 PM »
Yes after a fresh installation, now i'm running R03.043.066 everything works fine. Thanks alot.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #7 on: February 07, 2014, 05:04:48 AM »
Cool. In that case I suspect your original version (022) would also be fine after a re-install. Anyway - you're up and running so thanks for getting back.
