Hello Guest it is November 13, 2026, 10:01:57 AM
Author Topic: Drag knife  (Read 13827 times)
Drag knife
« on: February 02, 2014, 02:38:23 PM »
Simple question from a complete newbie
How do I stop the spindle from spinning for a drag knife?
THANKS!
Re: Drag knife
« Reply #1 on: February 02, 2014, 03:31:20 PM »
Don't start it.
If your g-code is starting it, then edit the code or the post to remove M3 commands.
Re: Drag knife
« Reply #2 on: February 03, 2014, 01:08:21 PM »
The code starts it.
A video by Donek, the company I bought the knife from, says to edit the code below then select the edited file as my post processor.
The example they used was a shopbot file where it read in the code "turning router on" then code following it.
Not knowing anything about g-code yet, without that "turn on / off...." text I'm clueless.
THANKS!
+ Mach2/3 - Vectric machine output configuration file
+ History
+ Who      When       What
+ Tony     15/11/2005 Written
+ Tony     06/01/2006 Added ATC option
+ Tony     14/05/2006 Fixed G20 inch in header
+ Tony     24/07/2006 Added G2 & G3 Arc support + removed (( ))
+ Tony     18/06/2007 Replaced the Tool comment
+ Mark     14/08/2008 Added G1 to Feed moves,
+                     Removed 2nd G20 in header.
+ Mark     28/08/2009 Added G91.1 to force use of incremental arcs
+                     Added Substitution, File & Toolpath Notes.
+ Mark     30/11/2009 Added TOOLPATHS_OUTPUT.
+ Brian    15/12/2009 Remove M05 from NEW_SEGMENT
POST_NAME = "Mach2/3 Arcs (inch) (*.txt)"
FILE_EXTENSION = "txt"
UNITS = "inches"
DIRECT_OUTPUT = "Mach|Mach4.Document"
SUBSTITUTE = "({)}"
+    Line terminating characters
LINE_ENDING = "[13][10]"
+    Block numbering
LINE_NUMBER_START     = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+    Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.4]
VAR Y_POSITION = [Y|C|Y|1.4]
VAR Z_POSITION = [Z|C|Z|1.4]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.4]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.4]
VAR X_HOME_POSITION = [XH|A|X|1.4]
VAR Y_HOME_POSITION = [YH|A|Y|1.4]
VAR Z_HOME_POSITION = [ZH|A|Z|1.4]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.4]
+    Block definitions for toolpath output
+  Commands output at the start of the file
begin HEADER
"( [TP_FILENAME] )"
"( File created: [DATE] - [TIME])"
"( for Mach2/3 from Vectric )"
"( Material Size)"
"( X= [XLENGTH], Y= [YLENGTH], Z= [ZLENGTH])"
"([FILE_NOTES])"
"(Toolpaths used in this file:)"
"([TOOLPATHS_OUTPUT])"
"(Tools used in this file: )"
"([TOOLS_USED])"
"[N]G00G20G17G90G40G49G80"
"[N]G70G91.1"
"[N]T[T]M06"
"[N] ([TOOLNAME])"
"[N]G00G43[ZH]H[T]"
"[N]M03"
"[N](Toolpath:- [TOOLPATH_NAME])"
"[N]([TOOLPATH_NOTES])"
"[N]G94"
"[N][XH][YH][F]"
+  Commands output for rapid moves
Re: Drag knife
« Reply #3 on: February 07, 2014, 06:46:03 PM »
Anyone? little help here? please?
Appreciate it.
Re: Drag knife
« Reply #4 on: February 07, 2014, 07:31:03 PM »
What is the actual software program you are using to generate your gcode, and what Windows operating system are you using with that program?
I assume it's a Vectric program, but which one?
John Champlain
Re: Drag knife
« Reply #5 on: February 07, 2014, 08:03:17 PM »
OK, I see that the partial Vectric post processor file you posted is a Cut2D file
All you need to do is delete only the lines that have M03 in them, no others, and save the file with a new name as the video explained.  In my copy, there are two such lines.
John
« Last Edit: February 07, 2014, 08:06:47 PM by Picengraver »
Re: Drag knife
« Reply #6 on: February 10, 2014, 04:36:41 PM »
Thank you John.
I'm now dragging my knife :)
Re: Drag knife
« Reply #7 on: February 10, 2014, 04:40:26 PM »
You're welcome.  Please post some pictures when you can.
John
