Hello Guest it is October 21, 2026, 04:42:14 PM
Author Topic: Side Effects  (Read 62758 times)
Side Effects
« on: January 31, 2014, 02:36:16 PM »
Another "Side Effect" of this so called global warming epidemic  ???
It seems to have created a spike in the cholesterol level of our water here.  :)
Russ
Re: Side Effects
« Reply #1 on: January 31, 2014, 04:16:15 PM »
This does not happen in Russia, vodka prevent that ;D
Jeff
Re: Side Effects
« Reply #2 on: January 31, 2014, 04:30:27 PM »
  :D :D
Good one Jeff ... THANKS!
 ;D
Re: Side Effects
« Reply #3 on: January 31, 2014, 07:03:03 PM »
Our "side effect" was the most snow we've ever had in one month, and the 8th coldest month in recorded history (coldest in over 35 years).
6 more inches coming tonight and tomorrow to start off the new month. ;)
Re: Side Effects
« Reply #4 on: January 31, 2014, 07:20:18 PM »
When you add energy to a system (warming) the oscillations get bigger, hotter summers and colder winters.  It may be cold now but summer temps are going to set records too.
Re: Side Effects
« Reply #5 on: January 31, 2014, 07:59:58 PM »
Just my 5 cents
Re: Side Effects
« Reply #6 on: January 31, 2014, 08:31:26 PM »
Its been kind of cool here too Russ. I may need you to send me some of that anti-freeze Jeff is carrying on about.
Re: Side Effects
« Reply #7 on: January 31, 2014, 08:56:49 PM »
In my part of Australia it's been between 35c and 40c (95f to 105f) for a while now and no rain for over a month. Still I would perfer to be here then where you guys are.
Steve
Re: Side Effects
« Reply #8 on: February 01, 2014, 06:29:58 AM »
.................the oscillations get bigger, hotter summers and colder winters.  It may be cold now but summer temps are going to set records too.
Holy CRAP ! ! !
Is there an "Anti-Vodka" available Ostie ? ? ?   ???
 Not sure I can handle 125F this coming summer.  :P  :)
Brett,   Jeff's medication is a "preventive", what I have is a "CURE ALL" ! ;D
 I'm still good on anti-freeze. (although the April supply is running a bit low) ;)
Even at these sub-zero temps, the snow and ice is mysteriously all melted within a perfect 60' radius of my liquor cabinet. ::) strange  ;D
Russ
Re: Side Effects
« Reply #9 on: February 01, 2014, 08:35:37 AM »
 ;D
I know why the snow and ice has melted. Gooooooooooooodddddddddddddddnnnnnnnnnnnnneeeeeeeeeeeeeeeesssssssssssssssss!  :o Cure all is right. A little bit of that stuff and absolutely nothing matters. I think you should label it Magic Eraser.  ;D
