Hello Guest it is November 24, 2026, 06:10:25 PM
Author Topic: Y axis not working  (Read 8857 times)
Y axis not working
« on: January 30, 2014, 04:44:49 PM »
Me and my friend are making cnc machine with 4 axis x,y,z and a. We are wiring one stepper motor at the time. X axis motor is running well, but now y axis is not working.
We wired everything the right way and motors are locked, the g code is running and x motor is moving but y motor is not working.
I'm using these motors and drivers
http://www.ebay.com/itm/USA-FREE-SHIP-PROMOTION-4Axis-Nema17-stepper-motor-4200g-cm-0-9degree-driver-CNC-/141131828408
i don't have picture here but this is the configuration
motor outputs
             step pin / dir pin / dirlow active/  steplow active   step port    dir port
x enabled    2             3          x                    x                     1            1
y enabled    4             5          x                    x                      1            1
z enabled    6             7          x                    x                      1            1
input signals
everything except e stop disabled
estop enabled
port 1
pin number 10
active low- enabled
other disabled
output signals
enable1   1   14   disabled
enable2   1   2     disabled
enable3   1   6     disabled
output1 enabled 1 9 disabled
this is the configuration.Can you tell me what's the problem of Y axis. We didn't try Z and A because we are connecting one by one.
Thanks!
Re: Y axis not working
« Reply #1 on: January 30, 2014, 05:13:16 PM »
it's okay we found the solution. We played with pin numbers in output signals x is 2 and y is 4 now and i suppose z will be 6 and a will be 8
