Hello Guest it is October 20, 2026, 03:04:52 PM
Author Topic: Reviving old machine using mach  (Read 110119 times)
Re: Reviving old machine using mach
« Reply #80 on: July 01, 2014, 01:31:18 PM »
Maybe use a MPG?
« Reply #81 on: July 01, 2014, 07:18:44 PM »
External mpg?
Sent from my iPhone
« Reply #82 on: July 02, 2014, 11:54:33 AM »
Yes.
« Reply #83 on: July 11, 2014, 10:43:18 AM »
and, how should i connect it?
Its already have one MPG - not sure whether i can use it with mach or not
What type of input is required by Mach for MPG to work? what settings needs to be set in Mach?
« Reply #84 on: July 13, 2014, 03:46:07 PM »
You can, if I recall, have up to 3 MPGs connected to Mach. You should find settings from Ports and Pins. Also I think the Tab screen has options on it for setting the MPG up.
