Hello Guest it is October 20, 2026, 07:57:47 PM
Author Topic: Reviving old machine using mach  (Read 110171 times)
Re: Reviving old machine using mach
« Reply #70 on: June 08, 2014, 12:19:40 AM »
hello hood
my motors have brake
how should i control them? should i use RUN to release the brakes? is there any code for individual axis run feedback? RUN will ON when cycle start is pressed
« Reply #71 on: June 08, 2014, 09:01:11 AM »
Normally the brake will be controlled via the servo drive, you could however control it from the enable outputs.
« Reply #72 on: June 08, 2014, 10:10:57 AM »
Yes i am doing it using output but i am using RUN signal
Is that any signal specific for axis only? So that i can control axis brakes independently
Sent from my iPhone
« Reply #73 on: June 08, 2014, 07:16:06 PM »
I do not know what drives you have but as said earlier it is normal for servo drives to have a means of enabling/disabling a brake.
If your servo drives do not have that option then the best option would be to have the brake connected to one of  the enable outputs in Mach. That would mean when when you take Mach out of reset the drive would get enabled and also the brake would be released.
If you require the brake to be only released at specific times then you would have to do something different but without knowing exactly what you are trying to achieve it is impossible to say what would be best.
« Reply #74 on: June 14, 2014, 06:33:58 AM »
No I mean E000, you do not enter th 0x
If you are meaning Jog the spindle from MPG  then the only way would be to use SwapAxis() and treat it as an axis.
I wrote e000 but its automatically taking 0xE000 and my second board doesnt work at all
Sent from my iPhone
« Reply #75 on: June 14, 2014, 08:35:51 AM »
Sent from my iPhone
OK I got it working. Charge Pump interlock Jumper was set wrong in second card
By the way, any one has set the MPG mode for 5 axis. That MPG which is shown while pressing TAB key
« Reply #76 on: June 14, 2014, 08:53:43 AM »
In Default MPG, code used are 307/8 for Push to jog X/y but its till A only. What if i want to add 5th axis button on that?
« Reply #77 on: June 30, 2014, 07:47:27 PM »
Hood.. Can you help??
Sent from my iPhone
« Reply #78 on: July 01, 2014, 07:52:15 AM »
Afraid not, if there is no OEM for that then it would seem there is no built in function in Mach.
« Reply #79 on: July 01, 2014, 09:43:10 AM »
Then what should i do for jogging 5th axis??
My normal operation will be jogging only so i need simple jogging function
Sent from my iPhone
