Hello Guest it is November 13, 2026, 05:10:08 PM
Author Topic: JOG = off. Causes JOG to continue ?  (Read 11246 times)
« on: January 29, 2014, 03:12:58 PM »
Moved the discussion from "General forum" to here.
I set  an 8x8 input matrix, and assign some for JOG XYZ, (One key for X+ another for X- etc)
Following is observed:
- Continues JOG is selected
- Pres_and_hold a button: Causes axis to JOG, Release = Stop.
If I then toggle the JOG to OFF, the I cannot JOG on the regular PC-Keyboard, but
When I Press and release a key via my PoKeys input matrix, the Axis starts and Continues to JOG, untill "Stop" or "E-stop" is activated ?!
(This is valid for all axis in both directions)
If I select MPG-mode (Instead of continues) and THEN toggle JOG = Off then it's all good, nothing moves, just as I expected the JOG = Off function to work ?
(Further I have some issues with the formatting of DRO in the LCD, but I'm not sure if bug-reports are in this forum ?)
Best Regards, Bo Andersen.
Offline NeoTO
  •  504 504
    • PoLabs
Re: JOG = off. Causes JOG to continue ?
« Reply #1 on: January 30, 2014, 09:57:12 AM »
Hi, Bo
Please forward all bug reports to matevz@poscope.com.
We will check the jogging issue. Which PoKeys version has been installed? And most importantly - is PoKeys device being used as a motion device or only as an interface?
Matevž
« Last Edit: January 30, 2014, 10:22:50 AM by NeoTO »
