Hello Guest it is November 10, 2026, 01:55:22 AM
Author Topic: Script to configure Input Pins  (Read 5988 times)
« on: January 27, 2014, 11:03:24 PM »
I have looked at some scripting and see fields can be read from Mach3 screens.  Is there a runtime command that will enable signals, set pins and also clear or set the Active Low in the Engine Configuration Ports & Pins dialog box?
Any help much appreciated.
