Hello Guest it is November 22, 2026, 05:28:44 PM
Author Topic: Can't write to OemDro 39, Spindle RPM?  (Read 8867 times)
« on: March 06, 2007, 09:15:41 PM »
Are some DRO's Write protected?
Here is a section of my macropump:
sov=GetoemDRO (202)
If  (sov <= 9500) Then
   'set spindle speed to 9000 RPM
   ActivateSignal (output6)
   DeActivateSignal (output7)
   DeActivateSignal (output8)
   DeActivateSignal (output9)
   SetOEMDRO (39,9000)
   End If
If (sov > 9500) And (sov <= 10500) Then
   'set spindle speed to 10000 RPM
   DeActivateSignal (output6)
   SetOEMDRO (39,10000)
   End If
Everthing is working fine except the SetOemDro command.  Any ideas?
Eugene
Re: Can't write to OemDro 39, Spindle RPM?
« Reply #1 on: March 06, 2007, 10:16:51 PM »
Well, I must have looked over the wiki 5 times and didn't see the "not all dro's can be written" statement.  Sometimes I have to post a ? here in order to be able to see!
« Reply #2 on: March 07, 2007, 03:29:36 PM »
You might try DRO 817. Its called "Spindle Requested DRO".
39 is called True Spindle and it shows the measured speed, so you cant change that.
When Im writing wizards I often open the 1024.set screen and select buttons I want to use and see their properties. Its often quicker than trying to read through the long lists of codes.
You might also use a Code command and issue the gcode for speed- Code "s 9000" or whatever speed you want. I think its legal to use an S word alone
« Last Edit: March 07, 2007, 06:33:37 PM by Ron Ginger »
