Hello Guest it is November 22, 2026, 12:41:49 PM
Author Topic: 5AXIS  (Read 10969 times)
5AXIS
« on: January 22, 2014, 06:32:37 AM »
Hello back again i emailed and asked if the license i previously paid for would be good for 5 axis, they said it would
sooooo
back when i set up my first 3 axis machine there was a specific version, not much older, but not the newest version of mach3 that would run without bug issues
does anyone know of a specific mach i should download for the chinese 5 axis engraver im buying
also can anyone give me advice on how you would go about tuning the 4th and 5th axis motors, cause ive got no clue
thanks in advance for any and all advice
Re: 5AXIS
« Reply #1 on: January 22, 2014, 12:40:40 PM »
The version I use  is 057 but others say 062 is also ok.
Regards tuning, it will all depend on the hardware but basically if they are rotary axes then instead of steps per mm or inch you will use steps per degree.
Re: 5AXIS
« Reply #2 on: January 22, 2014, 01:49:20 PM »
this site is different than last i checked here
where can i find that version you mentioned because all i seen on the site was 43
Re: 5AXIS
« Reply #3 on: January 22, 2014, 02:05:54 PM »
Re: 5AXIS
« Reply #4 on: January 22, 2014, 02:24:14 PM »
as ive stated in the past
you the man
thanks again
