Hello Guest it is November 13, 2026, 09:40:50 AM
Author Topic: ESS - BOB configuration problems - "Automated Setup of Inputs"  (Read 9130 times)
« on: January 20, 2014, 11:04:49 PM »
Just setting up a new ESS board to my existing BOB and while trying to use the Automated Setup of Inputs, I get a message that says "This is only for printer port modes".
Can I still use this to set up limits and homing or do I need to do something different?
Any help would be appreciated.
Ramon
Re: ESS - BOB configuration problems - "Automated Setup of Inputs"
« Reply #1 on: January 21, 2014, 02:04:46 AM »
You need to enter the port and pin numbers normally. If you have put the machine together yourself you will know which port and pin you have connected things too, so it should be easy enough to set things up.
