Hello Guest it is November 12, 2026, 08:49:08 AM
Author Topic: Automation with C# VS2013  (Read 20743 times)
« on: January 19, 2014, 09:41:52 AM »
Anybody know how to automate Mach3 R3.043.066 from C# VS2013?
Code below compiles fine then gives: "An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in mscorlib.dll"
The application was built for X86 and both Mach3 and the app are running as admin.  Also, I reinstalled Mach3.
Thanks in advance.
using System.Runtime.InteropServices;
namespace AutomationTest
    public partial class Form1 : Form
        private Mach4.IMach4 Mach = null;
        private Mach4.IMyScriptObject Script = null;
        private void button1_Click(object sender, EventArgs e)
            Mach = (Mach4.IMach4)Marshal.GetActiveObject("Mach4.Document");   <<<== ERROR HERE
            Script = (Mach4.IMyScriptObject)Mach.GetScriptDispatch();
            Script.Code("G1 X2 Y2 F400");
Re: Automation with C# VS2013
« Reply #1 on: January 08, 2016, 02:56:06 PM »
Hello.
I think you have to start Mach3 before you build it in Visual Studio.
Greetings from Germany, Martin
« Reply #2 on: July 04, 2018, 11:49:19 AM »
 Hi
I am using C# to automate Mach3. But i am stuck how to displace Gcode running in C#
If you guys know please help
