Hello Guest it is November 13, 2026, 03:17:07 PM
Author Topic: Cable Carrier  (Read 8261 times)
Offline kolias
  •  1,165 1,165
Cable Carrier
« on: January 17, 2014, 11:17:41 AM »
Never used before these black plastic cable carriers but now I got them and they are 1.5" wide by 1/2" high. They are installed on the A axis (40" Long) and X axis (32" Long) and doing a good job but when I move the A axis I hear an occasional noise like krack-krack which I can't pin point but I'm sure its coming from the cable carrier. I have no problem with the X axis carrier but it has less cables inside.
Do you normally apply any lubricant on the joints of these carriers and if yes what kind?
I do have a silicone based spray lubricant but would it affect the cables inside the carrier?
Nicolas
Re: Cable Carrier
« Reply #1 on: January 17, 2014, 12:57:13 PM »
Even so-called self-lubricating materials benefit from initial lubrication. Silicone spay is an excellent choice for this and it won't hurt the cables.
