Hello
Guest
it is
November 09, 2026, 04:09:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Modbus
ModIO Power In
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ModIO Power In (Read 27993 times)
HillBilly
185
ModIO Power In
on:
March 06, 2007, 08:22:09 AM »
Is it OK to bypass the regulator on the ModIO and supply 5 volts regulated to the terminals ( Labeled 5 volt and ground.)?
Darek
Logged
Peter Homann
518
Re: ModIO Power In
Reply #1 on:
March 06, 2007, 02:22:22 PM »
Hi Darek,
Yes you can supply the ModIO with aregulated 5Vd supply via the apropriate screw terminals. Just make sure you don't connect a supply via the barrel jack or the Vac screw terminals.
Cheers,
Peter.
Logged
Homann Designs
http://www.homanndesigns.com
HillBilly
185
Re: ModIO Power In
Reply #2 on:
March 06, 2007, 06:00:18 PM »
Hey peter,
Thanks for the affirmation! I have been using one with a cutoff USB cable for power.
Darek
Logged
Print
Pages:
1
Go Up
« previous
next »
