Hello Guest it is November 10, 2026, 01:55:11 AM
Author Topic: Scripter compile error in  (Read 27029 times)
« on: January 15, 2014, 06:06:39 PM »
I'm making my own wizard with Machscreen and have run into the following problem.
When clicking on the "POST CODE" button, nothing happens, and then when clicking on the "EXIT" button, I get back into Mach 3 (the latest version) and I get the message "Scripter compiler error: In"
The VB code assigned to my "POST CODE" button is very simple and I get no syntax errors.  It starts and ends just like all the other wizards...
Sub Main()
DoOEMButton (169)
OpenTeachFile "example.tap"
CloseTeachFile
call LoadTeachFile()
End Sub
Main
All the lines in between are mostly:  Code "example yada yada yada"
There are a few if/then statements which decide which "code" line to print to the file, but that's pretty much it.  All of the calculations are done in the g-code itself using #*********x variables, rather than in the VBscript. This makes for easy tweaking of the gcode file without redoing the wizard.
Why the compile error?
Re: Scripter compile error in
« Reply #1 on: January 15, 2014, 06:41:57 PM »
You're getting the Scripter Compiler error in your wizard, you probably just don't have anything to display it.
Usually, it's due to a syntax error, but without seeing the code, it's nearly impossible to say.
« Reply #2 on: January 15, 2014, 07:43:33 PM »
Try copy/pasting all your code into the VB editor within Mach3, then either try to run it (using the buttons in the editor) or do a save-as to MCC, and the VB editor may flag the error.  Usually I find the cursor will jump to the location of the error.
Eric Brust
« Reply #3 on: January 15, 2014, 08:17:59 PM »
Thanks for the help.  I used the editor in Mach3 and am getting the cursor to point to the syntax errors.
The first one is in an if/then statement.  Here's the snippet of code...
   If GetUserLED(1063) Then
      If FinishCutDirection = 1 Then
         Code "(Cut initial circle)                 G91 G3 x0 y0 i#1001 j#1002"
         Else
         Code "(Cut initial circle)                 G91 G2 x0 y0 i#1001 j#1002"
      End If
      Code "(Set abs mode)                       G90"
      Code "(Start finishing subroutine)         M98 P1234 L[90/#4005]"
      Code "(Move to final circle start)         x[#1001+#5002-#5007] y#1002 z[#1003-#2001]"
         Code "(Cut final circle)                   G91 G3 x0 y0 i#1001 j#1002"
         Else
         Code "(Cut final circle)                   G91 G2 x0 y0 i#1001 j#1002"
      EndIf
      Else
      Code "(Start finishing subroutine)         M98 P1234 L[360/#4005 + 1]"
   End If
It is highlighting the 3rd to last line, "Else", as the error.  Can I not nest the if/then statements as I did?
« Reply #4 on: January 15, 2014, 08:23:06 PM »
There are two more syntax errors I'm getting:  The next one is from my last 2 lines of code:
CloseTeachFile
Call LoadTeachFile()
End Sub
Main
It highlights "End Sub" as the error.
And if I comment that line out of the code, it highlights the blank space on the next line of code after "Main" which is the last line.  I keep removing any blank characters or spaces after the last line, but every time I run the code it adds that blank character back and highlights the white space in the editor where the character would be.
« Reply #5 on: January 15, 2014, 08:25:27 PM »
         Else
      End If
         Else
      EndIf
      Else
   End If
If you copy/pasted exactly as the script is, you have a typo in the 'END IF' above the else statement it is failing on.  you are missing a space.  Typos get to be a killer for stuff like this :)
regards,
Eric
« Reply #6 on: January 15, 2014, 08:29:52 PM »
CloseTeachFile
End Sub
Main
Get rid of the last 'main' (it shouldn't be there), and I think you are missing a space for 'close teachfile'.  EDIT:  'closeteachfile()' should be OK, forget my comment about the space....  good luck!
Eric
« Last Edit: January 15, 2014, 08:35:31 PM by eabrust »
« Reply #7 on: January 15, 2014, 08:35:30 PM »
         Else
      End If
         Else
      EndIf
      Else
   End If
regards,
Eric
Grrrr.  No matter how many times I looked at that, I missed it.  It doesn't use a space in another application I use for microchips so that's what I am used to seeing.  That's why I missed it.
« Reply #8 on: January 15, 2014, 11:55:22 PM »
One more thing, how do I fill out the description and author that is visible on the wizards menu?
« Reply #9 on: January 16, 2014, 06:10:51 AM »
They are text labels placed on the screenset that do not display. I don't have Mach3 here, but you should be able to look at one of the default wizards and figure it out. The Mach2 customization guide also tells you how to do it.
