Hello Guest it is October 21, 2026, 06:10:09 AM
Author Topic: Thread Milling cutters  (Read 66295 times)
Re: Thread Milling cutters
« Reply #10 on: January 17, 2014, 10:33:36 AM »
I would say that the internal insert has greater relief. On the outside of a part the surface curves away from the insert. In a hole the surface curves towards the tool so it could rub if you don't have enough relief.  I would guess that an internal insert might work okay for occasional outside threading. Certainly worth a try I would think. If I only had a couple of threads to do that is what I would do.
« Reply #11 on: January 17, 2014, 01:51:10 PM »
They are also different "hands"  (L/H and R/H)  , especially on a lathe.
Graham
« Last Edit: January 17, 2014, 01:58:19 PM by GRAYHIL »
« Reply #12 on: January 17, 2014, 06:21:22 PM »
Yes, you  are right they very well could be.  I thinking in milling terms.
