Hello Guest it is November 18, 2026, 02:09:58 PM
Author Topic: Job not visible in Table display  (Read 8396 times)
« on: January 10, 2014, 07:51:25 AM »
I tried to find a solution for this but didnt have much luck. Im posting a screen shot of a simple piece of gcode Im using for testing purposes while I get my machine setup. The problem is the job appears way off screen in Table Display. If I go back to Vcarve and set the origin to the bottom left then recalculate the toolpath, save it then bring it up in Mach it appears correct. Now this is easy enough to do on files I create but Ive gotten a few from the internet that the origin was set in another corner or the middle even and I cant get it to appear correctly in Mach.
Is there a way to fix/edit the code/files so they are sit on the Table correctly?
Re: Job not visible in Table display
« Reply #1 on: January 10, 2014, 08:01:12 AM »
Geez nevermind guys Im a total moron sometimes. My darn offsets got changed and I never bothered to check them. Moderators please feel free to delete this entire thread!!
