Hello
Guest
it is
November 13, 2026, 03:02:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach 3 with Heidenhain Control
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 with Heidenhain Control (Read 14827 times)
Scott Pancheau
29
on:
January 09, 2014, 07:23:35 PM »
I have acquired a Bridgeport mill with a heidenhain control. I am wondering if there is a post proccessor for the code generated by mach and lazy cam to feed needed form of ISO code to control. It seems to have a lot of different g code meanings and a diff. way to define arcs than mach. I can just use a dnc program with a few macros to feed mach code into my allen bradley and it works great but not so with heidenhain. Any help appreciated.
Logged
Re: Mach 3 with Heidenhain Control
Reply #1 on:
January 10, 2014, 06:35:00 AM »
I have not seen any PP info to modify it for LazyCam as LC is what it is and may be better to use different software. See Page 32 in the Lazycam Manual which can be found in Member's Doc's as LC program options along with how Mach is configured is used for gcode output. I don't know the differences in gcode between Heidenhain and Mach but as you stated and as shown on page 32 what gcode produced for the Heidenhain controller must be appropriate.
Logged
Scott Pancheau
29
Reply #2 on:
January 10, 2014, 08:19:34 AM »
Thank you Rich. Guess that is why I came up empty searching on line and in forums. The man I purchased it from uses visual mill and I think he developed his own PP. He said he would help get me up if I bought that same program. It is reasonable priced but way more than Mach and I love Mach after using it for some tiime. I am really a slow learner on code variables, and he indicated the program has a kinda steep learning curve.
Thanks Again
Logged
Carnoustie, Scotland
Reply #3 on:
January 10, 2014, 12:46:06 PM »
Mach is a controller, it is not for producing code, so no post processor for Mach.
Logged
Scott Pancheau
29
Reply #4 on:
January 11, 2014, 09:40:19 PM »
Thank you Hood,
Scott
Logged
Reply #5 on:
January 12, 2014, 02:49:27 AM »
I have looked and BobCAD has a load of PP's for use with Heidenhain, Dolphin has some as well, whether they are for the model you have or even how well they work I have no idea. It is however two CAMs you can look at.
Logged
Scott Pancheau
29
Reply #6 on:
January 13, 2014, 03:32:11 PM »
Thanks again Hood. I am in the process now of evaluating some options.
Logged
Print
Pages:
1
Go Up
« previous
next »
