Hello Guest it is October 28, 2026, 08:44:14 AM
Author Topic: How to use Modbus data as axis data  (Read 10376 times)
« on: January 06, 2014, 05:25:55 PM »
I have a siemens s7-200 cpu 224xp connected to 2 rotary and 1 linear encoders. I send these data over modbus to mach3. I see data at brain control. How can i use these data as X, Y and Z axis data?
Re: How to use Modbus data as axis data
« Reply #1 on: January 07, 2014, 06:40:59 PM »
here is my encoder valu sent by modbus. i can see encoder value here and x encoder position value.
however i want to see encoder value with x axis value updated automatically
if i click on Load to DRO encoder value goes to x axis DRO.
How can i do encoder value automatically loads to X axis DRO?
Helps are appreciated.
« Reply #2 on: January 12, 2014, 09:34:36 AM »
You are trying to get a closed loop system. It's impossible.
Alex
« Reply #3 on: January 12, 2014, 04:01:36 PM »
Thank you for your reply. After reading manuals and visiting forum messages, i found that. Mach3 is not for closed loop systems. Now i am trying Linuxcnc.
