Hello Guest it is November 23, 2026, 02:07:34 AM
Author Topic: what is a xml file!?  (Read 10612 times)
« on: January 03, 2014, 04:58:34 AM »
What is a xml file? Do i have to make one file to get the Gcode to work okay??
Thanks!
Finland
Re: what is a xml file!?
« Reply #1 on: January 03, 2014, 05:20:55 AM »
Answered in your other post.
« Reply #2 on: January 03, 2014, 05:23:49 AM »
Yes but does it come automarically? Must i have it to get the gcode to work?
I have made the picture in vcarve 6 pro and vertical..
« Reply #3 on: January 03, 2014, 05:30:59 AM »
I told you in your other thread, please respond there after as your problem is relating to that other thread and not this.
I will reitterate here but as said respond with your xml in the other thread please.
There are 3 default xml's when you install Mach, Mill, Turn, Plasma.
If you use one of the default profiles in Mach it will use one of the default xml's. If you create a custom profile then it will automatically create a custom xml.
