Hello Guest it is October 06, 2026, 01:07:48 AM
Author Topic: Microstepping  (Read 9118 times)
Offline kolias
  •  1,165 1,165
Microstepping
« on: January 02, 2014, 04:58:57 PM »
Happy New Year to all
No sure what the right number is to configure my motors on the motor tuning dialog in Mach3. I have ball screws with 10mm pitch and I will use 1/8 microstepping. I convert the 10mm to inches which is 0.39" and I use the following:
8 x 200 = 1600 x 0.39" = 624
Is the 624 the right number?
Nicolas
Re: Microstepping
« Reply #1 on: January 02, 2014, 05:12:18 PM »
No you will be 4064 if you are direct coupled.
1 inch is 25.4 so a 10mm pitch screw will have to turn 2.54 times for an inch, so 200 x 8 x 2.54 = 4064 steps per inch.
Offline kolias
  •  1,165 1,165
Re: Microstepping
« Reply #2 on: January 02, 2014, 06:07:43 PM »
Thank you Hood, I'm direct coupled so I will use 4064
Nicolas
