Hello
Guest
it is
November 14, 2026, 12:29:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Trouble getting a smooth cut
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Trouble getting a smooth cut (Read 14767 times)
Grumpy
17
on:
January 02, 2014, 02:50:34 PM »
I don’t know if this is a SceetCam or a Mach 3 question. I am having a problem with cuts not being smooth. As a example if I cut a 6 inch circle you get stepping of the table as it is making the cut leaving marks in the work piece This appears to be a happing in both the X & Y axis ( by stepping I mean the table is jerking as it make the cut ) There are some pieces that I cut where part of a cutout will be smooth and some will have this stepping.
The motor tuning is as follows
Steps / min 20054
Velocity 60
Acceleration 15
Step Pulse 0
Drive Pulse 0
I am using SceetCam and Mach3 any help you can give me with this problem would be greatly
appreciated
Logged
Carnoustie, Scotland
Re: Trouble getting a smooth cut
Reply #1 on:
January 02, 2014, 03:49:39 PM »
Would really need to see the code and your xml.
Logged
Grumpy
17
Reply #2 on:
January 02, 2014, 05:32:01 PM »
I am having a problem attaching the requested files will keep trying
Logged
Grumpy
17
Reply #3 on:
January 02, 2014, 05:33:01 PM »
requested files
Logged
Reply #4 on:
January 02, 2014, 05:37:48 PM »
Will also need to see the G Code you are having issues with.
Logged
Grumpy
17
Reply #5 on:
January 02, 2014, 05:43:03 PM »
This is a file I am having a problem with
Logged
Reply #6 on:
January 03, 2014, 02:24:25 AM »
Your code looks reasonable but it is quite long so maybe there are parts that are bad, can you tell me which section you are having the problems with?
Also do the DROs in Mach show that jerking movement?
Logged
Grumpy
17
Reply #7 on:
January 03, 2014, 10:55:38 AM »
I have attached a picture of what the cut looks like Code line N33210 - N42020. It is the inside cutout layer of the drawing. Also the DRO's appear to be smooth
Logged
Reply #8 on:
January 03, 2014, 12:02:44 PM »
To me that looks like backlash/slop in an axis, ie the cutter is pulling and pushing the axis about.
Logged
Print
Pages:
1
Go Up
« previous
next »
