Hello Guest it is October 05, 2026, 10:08:12 PM
Author Topic: Picture not okay....  (Read 31871 times)
Re: Picture not okay....
« Reply #10 on: January 04, 2014, 07:59:03 AM »
What Revision  of Mach are you using?
« Reply #11 on: January 04, 2014, 09:21:15 AM »
Sorry i'm bad at this English... Can you explain in any other way what you mean?
Thanks!!
« Reply #12 on: January 04, 2014, 09:26:49 AM »
See attached pics.
« Reply #13 on: January 04, 2014, 09:42:30 AM »
Thanks! It is Version R1.83.027
« Reply #14 on: January 04, 2014, 09:48:41 AM »
That is probably 7 years old, would suggest you update. However I would suggest you do not use the latest version as it has quite a few bugs, best to get maybe to use this one.
ftp://anonymous@machsupport.com/Mach/Mach3Version3.043.062.exe
« Reply #15 on: January 05, 2014, 06:22:46 AM »
Thanks! Now it is updated but it works about 19sec and then it stops to engrave...
What is wrong or what have I done wrong?
Thanks!
-Thomas
« Reply #16 on: January 05, 2014, 06:28:23 AM »
That is strange, maybe something not quite right with the xml and the big jump in updates.
Can you attach the xml for the current setup so I can compare and see if there is an issue.
« Reply #17 on: January 05, 2014, 06:33:36 AM »
Here is the xml file.
Thanks!
« Reply #18 on: January 05, 2014, 06:38:14 AM »
Ah ok I see your problem right away.
You are using a pirated licence so Mach is treating your install as a demo so you are restricted to 500 lines of code amongst other things.
« Reply #19 on: January 05, 2014, 06:40:42 AM »
What! I bought this machine from ebay 2 months ago and they told me that the mach3 software is not pirate...
