Hello Guest it is October 21, 2026, 12:18:16 PM
Author Topic: need help  (Read 8813 times)
need help
« on: December 31, 2013, 10:56:25 AM »
I got through about 98% of a job, and then the Y axis went askew, probably due to static electricity...I need to know how to pick up where the router left off so I can finish the job.
I know the line it left off at, so could someone give me the proper steps to run the "Next LIne" command or "Start Here" command...not sure what the proper steps are?  Thanks!  Happy New Year
to everyone here.
Re: need help
« Reply #1 on: December 31, 2013, 11:26:08 AM »
Haven't used Run From Here in ages.......
Click in the program gcode window, scroll down to the line, click run from here button, cycle start flyout ( accept or change info ), click
ok.
BUT......................
Fix your noise problem and if it skipped I am not sure you really have the exact line that it left off at.
Maybe somebody who uses run from here a lot can add comments.
BTW, Can never find anything when searching as i know there are other posts worth reading,
here is a link:
http://www.machsupport.com/forum/index.php/topic,4033.msg175450.html#msg175450
« Last Edit: December 31, 2013, 11:32:09 AM by RICH »
Re: need help
« Reply #2 on: December 31, 2013, 11:44:00 AM »
Appreciate your reply, Rich.  Thanks!
