Hello Guest it is October 23, 2026, 07:49:19 PM
Author Topic: FeatureCam  (Read 11782 times)
FeatureCam
« on: December 26, 2013, 10:33:00 AM »
Need some coaching.... ???
Trying to run current trial version of Mach3
Using Featurecam 2014
seems to have trouble processing/executing G2 and G3 codes
Have i & j codes set to incremental
Mach3 just stops when it hits a G2 or G3 code
Roger Olson 423-742-4583
Re: FeatureCam
« Reply #1 on: December 26, 2013, 10:49:35 AM »
Hi Roger,
 post the GCode file you are having trouble with.
Might then see what is going on.
Russ
Re: FeatureCam
« Reply #2 on: December 26, 2013, 10:57:48 AM »
 :)Russ
Here is a portion of my G code...
Mach3 stops at the first G2..... NOTE works if I remove the i & j and change G2 to G1
(FM2)
N15 G90
N20 G00 X0 Y0 Z0.25 F15.0
N25 M06 T1
N30 G43 H1
N35 S2482 M03
N40 M08
N45 G00 X4.4668 Y6.0029 Z1.0
N50 G00 Z0.1
N55 G01 X4.4668 Y6.0029 Z-0.25
N60 G01 X4.6895 Y5.5 Z-0.25
N65 G02 X5.5 Y4.6895 I-2.1895 J-3.0
N70 G01 X6.0029 Y4.4668 Z-0.25
N75 G01 X5.9637 Y3.7634 Z-0.25
N80 G01 X5.5 Y4.0592 Z-0.25
N85 G03 X4.0592 Y5.5 I-3.0 J-1.5592
Re: FeatureCam
« Reply #3 on: December 26, 2013, 12:52:03 PM »
Hi Roger, you program worked fine on my Mach with the incremental box ticked for I&J and the distance move set to Absolute.  Jim
« Last Edit: December 26, 2013, 01:01:40 PM by jimthefish »
Re: FeatureCam
« Reply #4 on: December 26, 2013, 04:27:16 PM »
Same here.
John Champlain
Re: FeatureCam
« Reply #5 on: December 27, 2013, 09:00:55 AM »
 Thanks for the feedback.  I think I have found my problem.  After studying the Mach3 list of G-codes, I found G90.1 for Turning on i and j incremental moves.  PostedG90.1 at the beginning of my Gcode.  My programs seem to be running fine.   Thanks again for your input.
Rog
