Hello Guest it is October 21, 2026, 02:51:59 PM
Author Topic: Ref All Home Moves .2 and stops. Won't go home  (Read 15212 times)
Offline pofo
  •  55 55
« on: December 23, 2013, 04:23:17 PM »
I have Z home enabled. X and Y are disabled. I have soft limits of +/-100,000. The input switch is not active.
I hit the Ref All Home button and the Z axis moves +.200 and stops. The Z DRO resets to whatever the initial value was. That is, if it started at -2.00, it travels .2, stops @-1.8  and resets the DRO to -2.00. No error message.
What am I doing wrong?
Re: Ref All Home Moves .2 and stops. Won't go home
« Reply #1 on: December 23, 2013, 05:20:29 PM »
In Config >Homing/Limits, do you have a Home Offset of -2?
If so, then noise is probably triggering your switch.
Offline pofo
  •  55 55
« Reply #2 on: December 23, 2013, 05:52:16 PM »
The home offsett is zero. I don't think it is noise as the behavior is consistent.  I can have the Z anywhere on its travel and have the DRO set to any number. It always moves +.2 and stops.
« Reply #3 on: December 24, 2013, 01:47:18 AM »
please attach your xml.
Offline pofo
  •  55 55
« Reply #4 on: December 24, 2013, 03:59:42 PM »
Thanks for the offer Hood. It was operator error. The button had the legacy DoButton code. I switched it to DoOEMButton and it worked.
« Reply #5 on: December 24, 2013, 05:13:14 PM »
Strange  the DoButtons should work fine but as long as you have it working thats all that matters :)
Offline pofo
  •  55 55
« Reply #6 on: December 24, 2013, 05:14:35 PM »
It's running through a DSPMC. That may have something to do with it.
« Reply #7 on: December 24, 2013, 05:18:36 PM »
ah ok. Is it version 066 of Mach by any chance?
Offline pofo
  •  55 55
« Reply #8 on: December 24, 2013, 06:34:53 PM »
Yes, it is R3.043.066
« Reply #9 on: December 24, 2013, 06:53:19 PM »
Well there are known issues with it and homing, most likely when using external controllers. I have gone back to 056 or 057 .
