Hello Guest it is September 06, 2026, 06:05:25 AM
Author Topic: Motor stalling issue. (best I can describe)  (Read 29107 times)
Re: Motor stalling issue. (best I can describe)
« Reply #10 on: December 28, 2013, 11:13:09 AM »
Rich,
Skipping or what ever you want to call it. It only happens at the sign of a first movement. from then on no skips what so ever.
This can happen on any of the axis's at any place. I have not ascertained a certain location. As I do not feel its a mechanical problem
in any way, In fact I can just remove the steppers thus eliminating any mechanical issues. (which Im 99.9 % confident its not)
Repeat the skipping never never happens after the first movement at any location... "never" / "never has"
I should have added that when I do a pulse test. I get "every time" "Pulsing too fast" at the beginning of every test.. no matter what speed I choose.
then it clears up. and will run smoothly even at 100MHz. but just like the motors. only at the beginning. of each test segment.
Im starting to think its the PC. this is the third pc I read in another post/thread of someone having similar issues. And, the problem entirely went away after the third PC was introduced. perhaps Im just in need of the 4th pc!?...
Curious all. What do you think of the SmoothStepper possibility? seems to me it would solve any parallel port issue. Im just afraid Ill trade off my current dillema for another unknown problem.
-S
« Reply #11 on: December 28, 2013, 04:27:00 PM »
So try with PDMX bypassed, that leaves the drive PC and one motor unconnected to the axis, that eliminates the mechanical issues and also
a possible power supply issue.
I didn't see anything where you could jumper on the drive as I can on the 201's, but, with only one motor feed from the power supply and max torque
available even at 70% reduction should not have an issue. If your velocity is 100 use an acceleration of 10, 60 vel -  6 accel.
If it's a signal issue you need trace it at each interface and compare.
I have no firm answer for you so KISS applies, process of elimination / test!
« Reply #12 on: December 28, 2013, 08:58:32 PM »
Rich, Im not sure what you mean by bypassing the PDMX. If I do that how will I drive the motor?
Im on track with your earlier suggestions.
What I've done so far.
1: I disconnected all other motors and tried one all by it self. (Same results)
2: I built tried 2 other PC's this would make my 6th pc. Same results.
3: I need to swap parallel ports I have 2 of them One on board one an add on card. and try. (pending)
4: I can reliably reproduce this. Lets try with the Z axis.
Let me say this pre hand I can JOG the Z axis all day long and it hums like a well oiled sewing machine.
However I noticed. from the MDI I can say Zero the Z axis. and then issue a from Z0.0 G0 Z1.0 and it will proceed Upwards 1"
same if I tell it G0 Z-1.0 or even G1 Z1.0 or G1 Z-1.0. all moves are perfection....I have tried this dozens of times.
Now say from the offsets page. I try and Zero the Z axis. Im using Hoss's Blue screen. lets assume the Z is reading +3.0 the Z travels downward.
touches the touch plate. and zeros the DRO. then back off a slight bit and still zero'd the DRO. next move is the upward to the pre set/ desired height default is 1" (above the work) ... Right as the motor starts to move upward. and I do mean the instant. the DRO changes from 0.00 to some negative number lets say -.3256 at virtually the same time the motor makes its weird noise. then proceeds upwards to what ever the DRO reversed to plus the 1" so in my example final height? 1.3256...? go figure.... The DRO flashes so quickly I never noticed it. also while Im distracted from the motor noise.
All this sounds like a different problem. But in truth I could care less if the motor huffed and puffed and cried a pool of tears. so long as it does its job. perhaps the noise is negligible and my problem is not with the motors after all? I see/hear the motors whine. all while the expected travel distance isnt what I expect. perhaps the changing DRO is the culprit.?
Ideas?
I have 2 XML files for the same machine 1 is at 25000Hz and the other at 60000Hz both have the same anomolies.
but run fine otherwise.
whats appropriate?
Should I upload the files and create a link or post the file contents here.
MechMate25000Hz file
http://www.trickinteriors.com/MechMate-Mach3/MechMate25000Hz.xml
MechMate60000Hz file
http://www.trickinteriors.com/MechMate-Mach3/MechMate60000Hz.xml
« Last Edit: December 28, 2013, 09:04:09 PM by TheSniper »
« Reply #13 on: December 28, 2013, 10:25:28 PM »
bypassing the PDMX
I was thinking that you run the cable direcly from the drive to the stepper using the PP. That would eliminate the
BOB. Good grief you can't have 6 bum pc's!
 Stay away from using offsets or some screen other than the standard Mach Mill screen and state which Mach version your using.
I don't know what the Hoss screen does as compared to the standard one.
The intent is to just start at a rock basic system and if the problem goes away then adding a component or move may pinpoint.
I have no answer for you and just suggest testing unless someone chimes in with a solution based on similar experience.
PITA it is and if it makes you feel any better we all had something  which took more time to solve than we wish to say.
« Reply #14 on: December 28, 2013, 11:25:01 PM »
@Rich: I was not aware I could bypass the BoB...
I suppose I can google or do a search. and go from their.
Yes, I agree 6 pc's? and all with the same symptoms? not likely. But hey, I have had worse luck! :)
BTW thanks for all the  ideas thus far. I have another machine. that suffers no problems. 1 out of 2 aint bad eh?
-Sam
« Reply #15 on: December 28, 2013, 11:55:56 PM »
I had a similar issue once that drove me crazy.    Machine had worked perfectly for months and suddenly with no changes it started randomly stalling.   After going though everything (as I am sure you have) I checked my bios settings,  somehow during a reboot the parallel port got switched to standard mode.   I switched it back to enhanced mode and it's been fine ever since.
Something to check.
« Reply #16 on: December 29, 2013, 12:02:10 AM »
Something to check.
Thanks for the follow up.
Wow, I wish I were that lucky... My problem is just that, a problem... Ill keep beating it till one of us "it or me" gives in. :) I have btw tried changing my Port from one mode to the other and in my case? no change. :/ Glad to hear your back up and running though!
-S
« Reply #17 on: December 29, 2013, 02:05:05 AM »
All,
I am happy to report... I have resolved my So called motor stall on first event.
If you read the entire thread. though their are very few entries I hope I documented all I have tried and not tried.
One thing of interest and funny thing its probably the first thing I could have looked at.
is the version Im running. According to the help about screen I was on 3.043.00
I though??? heck, Ill try a beta if ones available. After looking I seen the current version is at 3.043.062
and I decide to read the change log. WHOA! lots O' changes...  (thanks for the fixes Art :) ) I re-installed the updated version and low and behold.
no stalling at first run. Heck even the Zero Z script runs ... Though I tweaked it to suit my needs. Im glad to post what I changed.
Other things I changed to test for the problem pre-updating the software.
1: I changed the parallel cables to the shortest ones I could find.
2: I created a profile with everything turned off except say one axis. absolute minimum setup.
3: My next step was going to bypass the BOB... (thanks to RICH's suggestion)
So, As of now.
1: Im back to my first PC! Geez that was pain full X 6!!! (5 spares in the bank-O'-matic tho.)
2: I'm locked on 60000Hz... Ill have to continue on with my tests. But as of now that particular issue is "SLAM DUNKED!"
3: Gecko 203V's set at 250, 50, 2us, 0 and Active High. just like the documentation says to set it at.
Thanks to you all. Im most grateful for your suggestions and time you gave me :)
-S
« Reply #18 on: December 29, 2013, 07:05:00 AM »
Glad you got her fixed.
Took a while, but,
, rang a bell and sometimes bells skip and takes few tries to hear it ring. ;)
« Reply #19 on: December 29, 2013, 08:07:29 AM »
All versions from 3.43.000 to 3.43.028 are rather buggy. Lots of changes and additions were made in these versions to support the MSM screenset
