Hello Guest it is November 13, 2026, 12:44:02 PM
Author Topic: Set a User LED to be On by default  (Read 16729 times)
« on: December 15, 2013, 03:29:03 AM »
Hello,
I created a User led with a user button, and i'd like to have this LED to be lit (turned on) by default when i launch Mach3
, and then when i would  press my button it would  turn the LED off.
I would like to know if there's a way to do this as LED states don't appear to be editable.
Maybe i should try to edit (carefully) the XML to force mach3 to light my LED as it starts ?
Re: Set a User LED to be On by default
« Reply #1 on: December 15, 2013, 06:47:27 AM »
You could create a macro to turn the LED on and have the m code of that macro in ithe initialisation string.
« Reply #2 on: December 15, 2013, 09:16:14 AM »
Thanks Hood.
Could you explain me more or give me an example please ?
You mean the LED would be turned on by the G-Code ?
But what if i don't load any G-Code ?
« Reply #3 on: December 15, 2013, 09:19:38 AM »
If you make a macro that switches the LED  On then save that macro in the macro folder of the profile you use. If you save the macro as , say, m101.m1s then enter m101 into the initialisation string  (General Config page) when you start Mach and press Reset the LED will be turned on.
« Reply #4 on: December 15, 2013, 09:39:38 AM »
OK thanks Hood !
I understand now.
I didn't know about that initialisation string...Now it's done .
Thanks again.
« Reply #5 on: December 15, 2013, 09:58:55 AM »
Hummmm.
How do i switch a LED ? (just the LED)
There's no kind of 'SetOEMLED' instruction.
I need to turn on an output to do this, but it uses a spare output...
« Reply #6 on: December 15, 2013, 10:04:47 AM »
I dont know what number you are using for the LED but something like this (where **** represents the number you use) should work.
SetUserLED(****,1)
« Reply #7 on: December 15, 2013, 10:05:50 AM »
SetUserLED (*********,1)
« Reply #8 on: December 15, 2013, 10:09:29 AM »
Excuse me , i haven't looked at the documentation enough.
I thought the SetUserLED wasn't existing !!!!!
I'm an idiot !
Thanks Hood & ger 21
« Reply #9 on: December 15, 2013, 10:23:51 AM »
No probs, the documentation is not the easiest to follow at the best of times :)
