Hello Guest it is November 22, 2026, 06:37:46 AM
Author Topic: Stopping Gcode during cycle  (Read 9644 times)
« on: December 13, 2013, 11:27:09 PM »
Hi guys,
I'm totally new here and recently got the G0704 running with Mach3 and MasterCAM V9.
In the MC 9,  I devided the tool path into sections hoping that I can stop at the end of the each cycle to change the end mill (2 flutes to 4 flutes, etc) or re-clamp certain area. How do I do this when the machine is running in Mach3? I tried using pause, but couldn't pause it at certain location.
MasterCAM Tool path.
Re: Stopping Gcode during cycle
« Reply #1 on: December 14, 2013, 03:06:56 AM »
The tool is the same for each step.
Program in a tool change for each step. Mach3 will stop and ask for a new tool  each time
« Reply #2 on: December 14, 2013, 03:10:31 AM »
Thanks! That makes sense. That would stop the cycle and prompt for "cycle start" even though I plan to use the same tool.
Offline ZASto
  •  434 434
« Reply #3 on: December 14, 2013, 04:09:10 AM »
The way that do things is to generate separate GCode file for each operation.
The machine that I'm sunning at the moment is a Chinese one with a pendant controller (Ti DSP inside) which is dumb enough, i.e. not interpreting all G codes well (broke some drills during G8x canned cycles) and at the moment I'm designing a BOB to dump the existing controller and to connect it to 'puter and drive it with Mach3.
My personality is who I am.
