Hello Guest it is October 01, 2026, 02:17:20 AM
Author Topic: G83 Mystery  (Read 73010 times)
G83 Mystery
« on: February 19, 2006, 12:49:04 PM »
I have the following code, which I'm entering manually to test:
G97 S1500
G95 F.008
G00 X0 Z0
G83 Z-2.2 Q.2
If the spindle is off, the G83 works fine.  If the spindle is on, the Z axis starts moving positive until I have to Stop it; I'm not sure where it's trying to go.
What am I misunderstanding?  Thanks.
Art
Re: G83 Mystery
« Reply #1 on: February 19, 2006, 02:14:16 PM »
Sounds like you have THC turned on in the config, or in the config/ports&Pins/Mill options you may have "Allow Z up down cxontrols when not in THC". If so, turn that off. Was that the trouble.. ?
Art
Re: G83 Mystery
« Reply #2 on: February 19, 2006, 04:16:44 PM »
I should have mentioned that this is Mach3 Turn.  Does this have any THC option?
Art
Re: G83 Mystery
« Reply #3 on: February 19, 2006, 04:29:53 PM »
Sorry, I should have know that due to the G83 beign used. The reason the Z isnt moving till the spindle is on, is beacsue your in feed/rev mode, but I dont know why the Z is moving..
  Whats the start position of the Z?
Brian:
  Any idea on this one, I havent used the G83 series in Turn as yet, I know the macro is new.. What are the parameters of it??
Art
Art
Re: G83 Mystery
« Reply #4 on: February 19, 2006, 04:47:50 PM »
Hi MArty:
DRill G83 X (optional)  Z (mandatory) Q (Mandatory) R(Mandatory)     G00 x0.0 z3.00
G83 Z-1.00 Q.1 R.1 F20
m30
  So you have no retract distance, Set an R of .1 for example..
Art
Re: G83 Mystery
« Reply #5 on: February 19, 2006, 05:29:20 PM »
I tested it here and it is working ver well!
Be sure you have the R val
www.newfangledsolutions.com
www.machsupport.com
Re: G83 Mystery
« Reply #6 on: February 21, 2006, 12:23:13 AM »
When I specify the R value, it works fine.
Thanks.
