Hello Guest it is October 24, 2026, 06:58:13 AM
Author Topic: Computer Problem  (Read 9501 times)
Computer Problem
« on: December 11, 2013, 03:56:49 PM »
I hope this is the correct section for this.
I have an older Dell Computer with Windows XP Pro installed. It's only used for the CNC with Mach 3 and has a couple older CAD programs and Sketch-up loaded on it.
Today it would not boot up and had a Disk Error. I tried several things and It posted an error and said I needed to reinstall the set-up. After much digging around I finally found the set-up disk and went to try to load it. It runs through several steps and then stops on loading the Windows XP Pro part. It sets at 0% for ever. I'm not sure what else to try. I not an IT guy by any means. Anyone have any thoughts?
I'm going to run back out to see if it's done anything in the last 45 minutes.
Re: Computer Problem
« Reply #1 on: February 05, 2014, 07:30:45 AM »
You may help with this link http://support.microsoft.com/kb/324103. Might be your problem will solve.
