Hello Guest it is November 16, 2026, 07:44:55 PM
Author Topic: using g-code outside of mach3  (Read 8976 times)
« on: December 10, 2013, 08:46:55 AM »
like the title says I want to make g code but custom G CODE , It is possible to do that with mach3? and how? I want to make custom g-code then export that to use with php
Re: using g-code outside of mach3
« Reply #1 on: December 10, 2013, 09:25:33 AM »
Define "Custom G-code"? You can create mach3 compatible g-code with LazyCAM, but I don't know if that's what you want?
