Hello
Guest
it is
October 23, 2026, 04:28:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Homann DigiSpeed DC-03 Setup Problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Homann DigiSpeed DC-03 Setup Problem (Read 14583 times)
Drew Pearce
38
on:
December 07, 2013, 12:09:43 AM »
Hi All,
I am running Mach3 via an Ethernet Smooth Stepper, and am still dong improvements on my 3 Axis router table.
I recently purchased a 2.2kW spindle & inverter.
http://www.ebay.com.au/itm/261203446783?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
And then got a DigiSpeed DC-03 from Homann Designs
http://www.homanndesigns.com/store/index.php?main_page=product_info&products_id=21
but who's manual seems to have been written by a Chinese gentleman who has not quite got the hang of Ingrish with many contridictions etc
http://www.homanndesigns.com/pdfs/DigiSpeed_GX_User030.pdf
The system as been connected as per one Homann helpful guides
http://www.homanndesigns.com/pdfs/EN012_V1.pdf
Except that I am running off Port 2 of the ESS
Now, I have gotten the forward / reverse working fine after searching here (thanks guys !)
(The Inverter only required Forward or Revese selected - no enable)
However, I can not get Mach3 to set the speed
When the direction is selected (M3 or M4), it ramps up to maximum Frequency
But, I can use the "trimpot" on the DC-03 to control the maximum speed
Ports & Pins for the Spindle are set to "Tick / 17 / 1 / Tick / Cross / 2 / 2
Spindle Setup / Motor Control is set to:-
Use Spindle Motor Output
PWM Control
PWMBase Ferq. 50
Help !!
Thanks in advance
Drew
Logged
Peter Homann
518
Re: Homann DigiSpeed DC-03 Setup Problem
Reply #1 on:
December 07, 2013, 01:46:04 AM »
Drew,
I guess your the Andrew that sent me an email earlier today?
Please be kind enough to point out which parts of the manual are Ingrish and where the contradictions are and I'll attend to them. Or is that just your way of asking for help?
Presumably you've set up the Smoothstepper to produce the PWM signal?
Also, the SmoothStepper requires you to set an acceleration value for the spindle axis.
Peter
Logged
Homann Designs
Drew Pearce
38
Reply #2 on:
December 07, 2013, 02:03:24 AM »
Hey Pete,
Yes, I sent you an email eariler, Didn't know you where in here too
Will email you the areas of contradiction off this forum.
Have selected PWM under Port & Pins / Spindle Setup / Motor Control
Or is there a separate area for the ESS?
And not sure where to set the acceleration value
Thanks for your help
Drew
Logged
Drew Pearce
38
Reply #3 on:
December 07, 2013, 02:15:59 AM »
Oops, yes, ESS Setup is set to PWM
Logged
Peter Homann
518
Reply #4 on:
December 07, 2013, 02:30:12 AM »
You also need to go into the Mach3 motor axis tuning tab and set an acceleration value for the spindle axis.
Peter
Logged
Homann Designs
Drew Pearce
38
Reply #5 on:
December 07, 2013, 03:29:54 AM »
Thanks Peter,
Redone all the spindle settings from scratch, and motor setup as per
http://www.machsupport.com/forum/index.php?topic=18580.0
And all seems to be working nicely now.
But J2 for DC/DC does not seem to want to give any more than 0.2V
Is there a way to check this?
Drew
Logged
Peter Homann
518
Reply #6 on:
December 07, 2013, 04:35:54 AM »
Do you have the optional DC/DC converter plugged into the DC-03?
Peter
Logged
Homann Designs
Drew Pearce
38
Reply #7 on:
December 07, 2013, 05:11:25 AM »
err, no
need to order an upgrade then
Thanks Peter
Logged
Peter Homann
518
Reply #8 on:
December 07, 2013, 07:31:45 PM »
If the VFD provides 10V, then use that. You will only loose a few % of the top speed.
Peter
Logged
Homann Designs
Print
Pages:
1
Go Up
« previous
next »
