Hello Guest it is October 23, 2026, 07:17:35 AM
Author Topic: Out of place axis movement  (Read 8149 times)
« on: December 06, 2013, 08:57:41 AM »
I've set up a couple OD grinders with Mach3 latest version .067. One grinder seems to do fine while the other, with identical code, makes "extra" movements. I've attached the part of the script that seems to be the culprit. Any ideas? I've deleted code that follows the problem.
 Tom
rem M1053 For PLUNGE GRIND To DIMENSION
Option Explicit
Dim FinishDim As Double
Dim ToGrind As Double
Dim HoldToGrind As Double
Dim Current As Double
Dim Remainder As Double
Dim SparkoutCounter As Integer
Dim RoughToGo As Double
Dim FinishToGo As Double
Dim RoughInc As Double
Dim FinishInc As Double
Dim Sparkouts As Integer
Dim LeftX As Double
Dim RightX As Double
Dim LeftFeedX As Double
Dim RightFeedX As Double
Dim PlungeFeedY As Double
Dim LeftDwell As Double
Dim RightDwell As Double
Dim AmountToGrind As Double
LeftDwell = GetOEMDRO(1110)
RightDwell = GetOEMDRO(1120)
FinishDim = GetOEMDRO(1056)
ToGrind = 0
AmountToGrind = 0
Current = 0
Remainder = 0
SparkoutCounter = 0
RoughToGo = 0
FinishToGo = 0
RoughInc = GetOEMDRO(1052)
FinishInc = GetOEMDRO(1053)
Sparkouts = GetOEMDRO(1054)
LeftX = GetOEMDRO(1060)
RightX = GetOEMDRO(1061)
LeftFeedX = GetOEMDRO(1162)
RightFeedX = GetOEMDRO(1163)
PlungeFeedY = GetOEMDRO(1064)
Current = GetOEMDRO(801)
ToGrind = Current - FinishDim
HoldToGrind = ToGrind * 1000000
ToGrind = HoldToGrind * .000001
AmountToGrind = ToGrind
rem last final Left over
Remainder = Current - FinishDim
HoldToGrind = Remainder * 1000000
Remainder = HoldToGrind * .000001
If (FinishDim <> Current) Then
   Code "M8 M3"
   Sleep 2000
rem turn On side travel
   If GetUserLed (1101) Then   (feed from left)
      Code "G90G01 X" & RightX & "F" & LeftFeedX
      Code "G04 P" & RightDwell
      Code "G90G01 Y" & FinishDim & "F" & PlungeFeedY     (*************** after this code the Y axis feeds back to original number,  before feed move)
      Remainder = 0                                                       (***** it doesn't do it when I run it on a computer in my office)
   End If
   If GetUserLed (1100) Then   (feed from right)
      Code "G90G01 X" & LeftX & "F" & RightFeedX
      Code "G04 P" & LeftDwell
      Remainder = 0
   End If
End If
Code "M9 M5"
Re: Out of place axis movement
« Reply #1 on: December 08, 2013, 11:45:10 AM »
The problem that can arrise when you mix Macro "CB with Gcode is that they can get out of order sync. When it does you will see all kinds of strange moves. OR none.
A liberal dose of
While Ismoving()
Wend
Statements after each instance of a Gcode call  or a write to a DRO/variable usually helps BUT it slows the program down and may cause less than smooth motion.
I find that mixing the two (macro/Gcode) does not always give stellar performance.
Now you can use macros to program the function as #vars then RUN the program from the Gcode side and get very good results. You may have to jump through a lot of hoops but it will work well that way.
