Hello Guest it is October 12, 2026, 05:59:28 PM
Author Topic: movement is not smooth  (Read 33663 times)
« on: December 05, 2013, 01:19:56 AM »
I have a problem for galil 21xx + Mach3.
1. Install Mach3 V.3.043.066 on win xp2007.
2.install plugin galil 4.5
This a problem
When I run the G code (attach file) When tool moves along the curve, why machines are so spastic (or movement is not smooth), I suspect that when the run g code first, it will not be a problem. but to run g code for a long time (about 30 minutes) is not smooth moves.
  But the same g code to control fanuc it Ok.
thank you
udom
Re: movement is not smooth
« Reply #1 on: December 05, 2013, 01:20:41 AM »
attach file
« Reply #2 on: December 05, 2013, 01:33:02 AM »
image for g code
« Reply #3 on: December 14, 2013, 09:34:06 AM »
Hi.
Please help me
I am still not resolved
Thank you
udom
« Reply #4 on: December 15, 2013, 07:29:40 AM »
try using CV ( G64 ) in your G Code
look ahead at least 20 lines.
just a thought
alex
« Reply #5 on: December 22, 2013, 07:31:37 PM »
I'm going to try.
Thank you
 udom.
