Hello Guest it is November 10, 2026, 01:54:17 AM
Author Topic: LoadRun hangs loading G-code?  (Read 10934 times)
« on: December 05, 2013, 12:20:52 AM »
(Inside of a macro)...
Code: [Select]
value1 = GetuserDRO(1005) 'Tube Dia scale
value2 = GetuserDRO(1000) 'Tube length
value3 = GetuserDRO(1001) 'Tube length
value4 = GetuserDRO(1003) 'Start Cope angle file
value5 = GetuserDRO(1004) 'End Cope file
Code "G51 Y"&value1
If value4 = 90 Then
LoadRun ("D:\Mach3\Gcode\90.NCF")
ElseIF value4 = 60 Then
Print 60
ElseIF value4 = 45 Then
Print 45
ElseIF value4 = 30 Then
Print 30
ElseIf value4 = 20 Then
Print 20
ElseIf value4 = 15 Then
Print 15
End If
Not sure WHY? I can run the program no problem. I've tried loading the file, that works. But DoOEMButton(0) didn't work.
RunFile didn't work.
Re: LoadRun hangs loading G-code?
« Reply #1 on: December 05, 2013, 10:31:45 AM »
Use the button DoButton(0) or  DoOemButton(800)
I believe that loadrun is busted. USE LoadFile()   THEN   RunFile() to make it work.
« Last Edit: December 05, 2013, 10:36:39 AM by BR549 »
« Reply #2 on: December 06, 2013, 11:20:02 PM »
Is this code too big for an macro? It hangs on the first file load running as an macro.
Code: [Select]
'M2000
value3 = GetuserDRO(1001) 'Rotation
indeg = (value3*0.00872222)
Code "G92 X0 Y0 Z0"
Sleep (1000)
Code "G50"
Sleep (500)
Code "G51 Y"&value1
If value4 = 90 Then
LoadFile ("Gcode\90.NCF")
LoadFile ("Gcode\60.NCF")
LoadFile ("Gcode\45.NCF")
LoadFile ("Gcode\30.NCF")
LoadFile ("Gcode\20.NCF")
LoadFile ("Gcode\15.NCF")
End If
While IsLoading ()
Sleep (2000)
Wend
Sleep(500)
RunFile ()
Sleep (5000)
While IsMoving()
Sleep (2000)
Wend
If value5 = 90 Then
ElseIF value5 = 60 Then
ElseIF value5 = 45 Then
ElseIF value5 = 30 Then
ElseIf value5 = 20 Then
ElseIf value5 = 15 Then
End If
While IsLoading ()
Sleep (2000)
Wend
Sleep(500)
Code "G0 X"&value2
While IsMoving()
Sleep(500)
Wend
Code "G50"
Sleep (500)
Code "G51 X-1.0"
Sleep (500)
Code "G0 Y"&indeg
Sleep (500)
While IsMoving()
Sleep(500)
Wend
Code "G51 Y"&value1
Sleep (500)
RunFile ()
But it runs just fine under the VB script editor  ???
Need to run it when the user pushes a button.
« Reply #3 on: December 06, 2013, 11:31:36 PM »
Well you have about 27 sec of sleep time ????
Are you sure that is not your problem ???
Just a thought, (;-) TP
« Reply #4 on: December 07, 2013, 10:01:14 AM »
No, runs great in VB script editor.
Re-saved it in the base mach dir and made a script button has -
RunScript ("filename")
Works awesome.
« Reply #5 on: December 07, 2013, 11:33:46 AM »
« Last Edit: December 07, 2013, 11:38:10 AM by Ya-Nvr-No »
