Hello Guest it is October 22, 2026, 02:42:52 PM
Author Topic: Display oem dro with math function in user dro  (Read 11829 times)
« on: December 01, 2013, 01:34:20 AM »
And do it in real time not on the push of a button?
I'm using a rotary axis setup as a normal axis based on circumference.
I thought it would be nice to see it in degrees too , in real time.
From what i read I'm dreaming...
Re: Display oem dro with math function in user dro
« Reply #1 on: December 01, 2013, 06:54:22 AM »
Use a macro pump and User DRO
« Reply #2 on: December 01, 2013, 10:07:31 AM »
Any sample code?
« Reply #3 on: December 02, 2013, 09:23:30 PM »
Nevermind, I got it.
My macropump.m1s looks like this...
Code: [Select]
value = GetOEMDRO(801)
SetOEMDRO(803,value/0.008722222)
« Reply #4 on: December 03, 2013, 12:42:52 AM »
OEMDRO 803 is the A axis distance to go DRO. I'm surprised you can write to it and would have thought it was a read only. I would edit the screen and use a UserDRO above 1000.
SetUserDRO(1100,value/0.008722222)
