Hello Guest it is November 13, 2026, 05:18:26 PM
Author Topic: Not able to get PoKeys56U to work with Gecko G320X  (Read 11042 times)
« on: November 20, 2013, 12:17:53 AM »
I have been trying to use pokeys56U to output step/dir to my gecko drives to control servo, following the instruction I still dont get anywhere, has anyone had luck doing this, and if so, any pointers?
Using Pokeys software 3.0.65 with Pulse engine enabled.
Russ
Offline NeoTO
  •  504 504
    • PoLabs
Re: Not able to get PoKeys56U to work with Gecko G320X
« Reply #1 on: November 20, 2013, 01:12:50 AM »
Do you get any movement in the DROs and PoKeys pulse engine positions?
Please install the latest version of PoKeys firmware and the new Mach3 plugin - it features a status screen that should show you the status of the Pulse engine.
Matevž
