Hello
Guest
it is
October 22, 2026, 02:46:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
Select DRO without mouse
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Select DRO without mouse (Read 12838 times)
Overloaded
4,923
on:
November 19, 2013, 07:23:42 AM »
Screens in general .... is there a way to highlight and scroll through the DRO's on a screen by using the keyboard only ... no mouse ? Like tabbing through ?
I have a very simple screen with 5 DRO's that require entered values.
All I need is a monitor, num pad, a few buttons and the dang mouse. ( touch screen would be handy ... maybe next time)
Just wondering.
Russ
Logged
ger21
6,295
Re: Select DRO without mouse
Reply #1 on:
November 19, 2013, 08:54:12 AM »
You can assign hotkeys to the DRO's, but I'm not sure if you can "tab" through them.
Logged
Overloaded
4,923
Reply #2 on:
November 19, 2013, 09:54:47 AM »
Hi Gerry,
I see one dro hotkey setting. That key will select whatever dro was last clicked with the mouse.
Do you know of a way to set different keys to different dro's ?
Thanks a bunch,
Russ
Logged
ger21
6,295
Reply #3 on:
November 19, 2013, 10:06:59 AM »
Yes, you can assign hotkeys in a screen designer.
Logged
Overloaded
4,923
Reply #4 on:
November 19, 2013, 10:22:24 AM »
Thanks Gerry, never noticed that before iin the Screen4 designer.
Works a treat !
Thanks again,
Russ
Logged
BR549
6,965
Reply #5 on:
November 19, 2013, 08:07:54 PM »
AH I learn something every DAY,
Logged
Print
Pages:
1
Go Up
« previous
next »
