Hello Guest it is November 10, 2026, 01:58:03 AM
Author Topic: script writing records using modbus in external device  (Read 6499 times)
« on: November 16, 2013, 11:13:11 AM »
Hi everyone !
Because my adventure with brains is in conflict to understand the logic of the lobe I decide try this time with a macropump for my target but, Even Im VB programmer Im not familiar with the script for mach3 so I need a little help from a good gui that can drop some instructions here and open a light in my darkness.
What I want to do is, the funcions or sub callings needed to write 2 different register via modbus.
Attached the Modbus control config. Thats works perfect using the test button, I can write in address 0 any value just a number for example 100, and also I can write value (also number) in address 66 both are holding registers.
but I dont  know how translate t his manual operation to the sentences in VB script.
Thats all that I need and then the rest of scrit of course I will deal with it.
Can somebody help me?
Thank you !
