Hello Guest it is November 12, 2026, 07:36:58 AM
Author Topic: CAD to lazy cam  (Read 10247 times)
airwolf68
CAD to lazy cam
« on: February 28, 2007, 03:07:30 PM »
I'm new to all this i am using auto cad 07 to lazy cam to get code.my problem is that i have a simple draw a eclipse and two circles i save as dxf file and try to bring into lazy cam i only have two chain they are the two circles but my oval is missing. i thing its because the item is not joined but do not know how to join
thanks for your help
Re: CAD to lazy cam
« Reply #1 on: February 28, 2007, 05:02:37 PM »
LazyCAM can't read an AutoCAD ellipse. Here's a workaround. In AutoCAD, type PELLIPSE and enter 1. Then draw your ellipse. It won't be a true ellipse, but you'll get an approximation made up of polyline arcs. LazyCAM should see it fine then. Also, be sure to save as a v12 .dxf
I have a macro that will export g-code from within AutoCAD, if you're interested.
http://home.comcast.net/~cncwoodworker/acad/downloads/AC2GCv039.zip
« Last Edit: February 28, 2007, 05:53:25 PM by ger21 »
