Hello Guest it is October 21, 2026, 07:32:23 PM
Author Topic: Newbie set up question  (Read 9675 times)
« on: November 10, 2013, 03:42:12 PM »
I just got Mach3 licensed got my ports configured and the motors tuned.  All axes responds well to manual control.   But when I try to run the roadrunner file recommended as a test in the videos I run into a problem.  The program seems to run to completion but it routes out the entire design in an area about 20mm sq.  I can’t image that this is the plan.  So I must have something misconfigured in Mach3.  The manual says I can scale a part but I don’t see where it tells me how.  I would appreciate any suggestions
Rich
Re: Newbie set up question
« Reply #1 on: November 10, 2013, 06:07:55 PM »
You can add a scale factor to any of the axis by putting a number other than 1 in the scale box ( next to the axis DRO )
« Reply #2 on: November 10, 2013, 06:38:20 PM »
Rich that worked thank you.  By using a scale factor of 10 in X & Y it routed out an image of about 4X3".  So I was able to determine that I could run and output code.  Something else I was wondering is how can I import a G code file and tell what the properties of the file are like units (inches or mm) or output size.
Rich
  •  9,374 9,374
« Reply #3 on: November 11, 2013, 12:42:28 AM »
Once you have loaded a GCode, open the 'Toolpath' screen and 'Program Limits' show the size.
« Reply #4 on: November 11, 2013, 01:59:56 AM »
Going back to your original post, the roadrunner is written in inch units but it does not have  G20 at the start to tell Mach. Thus if you run on a machine set up in metric units it will run in metric units, this shows the importance of all of your code defining the set up parameters such as G20/G21, G90.1/G91.1, G61/G64  etc etc. Making sure your code has such a preamble can save a lot of unexpected things happening ;)
