Hello
Guest
it is
October 21, 2026, 06:09:17 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Copy Config
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Copy Config (Read 22062 times)
Klaus1311
531
Re: Copy Config
Reply #10 on:
November 13, 2013, 06:18:35 AM »
Hi Roy,
when is this message appearing?
does this message popup direct after starting MachProfile, or when you select an Action, if so what action?
Klaus
The brain isn't a soap, it doesn't shrink when used.
Roy Smart
20
Re: Copy Config
Reply #11 on:
November 14, 2013, 08:25:41 AM »
Hi John,
I have tried again and it loads the program but all I then get are clear screens and the error message
The Mach3 LPT- driver will not work with this system. I think this because I am using a USB printer? Any ideas
how to solve this?
Regards
Roy
Klaus1311
531
Re: Copy Config
Reply #12 on:
November 14, 2013, 08:37:54 AM »
Hi Roy,
the error message abot LPT port belongs to the "Show params" dialog. Are you using "Show params" or "Show Settings" dialog?
Klaus
Roy Smart
20
Re: Copy Config
Reply #13 on:
November 14, 2013, 08:45:24 AM »
Hi Klaus,
When I run the program it starts with a blank screen. I clicked on ports and pins (Action).
Then I get the error message.
Regards
Roy
Klaus1311
531
Re: Copy Config
Reply #14 on:
November 14, 2013, 10:27:05 AM »
Hi Roy,
this message is meant as a warning, if you answer that dialog OK, MachProfile continues. If you want to print your Mach3 Settings, you have to use "Show Settings" in the Actions menu.
Klaus
Roy Smart
20
Re: Copy Config
Reply #15 on:
November 14, 2013, 10:36:35 AM »
Hi Klaus,
Many thanks for all your help, It is now working correctly and
I have the printouts required. I must have been making typo errors.
Thanks again
Best Regards
Roy
Print
Pages:
1
2
Go Up
« previous
next »
