Hello
Guest
it is
November 23, 2026, 11:03:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Copy Config
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Copy Config (Read 22676 times)
Klaus1311
531
Re: Copy Config
Reply #10 on:
November 13, 2013, 06:18:35 AM »
Hi Roy,
when is this message appearing?
does this message popup direct after starting MachProfile, or when you select an Action, if so what action?
Klaus
Logged
The brain isn't a soap, it doesn't shrink when used.
Roy Smart
20
Re: Copy Config
Reply #11 on:
November 14, 2013, 08:25:41 AM »
Hi John,
I have tried again and it loads the program but all I then get are clear screens and the error message
The Mach3 LPT- driver will not work with this system. I think this because I am using a USB printer? Any ideas
how to solve this?
Regards
Roy
Logged
Klaus1311
531
Re: Copy Config
Reply #12 on:
November 14, 2013, 08:37:54 AM »
Hi Roy,
the error message abot LPT port belongs to the "Show params" dialog. Are you using "Show params" or "Show Settings" dialog?
Klaus
Logged
Roy Smart
20
Re: Copy Config
Reply #13 on:
November 14, 2013, 08:45:24 AM »
Hi Klaus,
When I run the program it starts with a blank screen. I clicked on ports and pins (Action).
Then I get the error message.
Regards
Roy
Logged
Klaus1311
531
Re: Copy Config
Reply #14 on:
November 14, 2013, 10:27:05 AM »
Hi Roy,
this message is meant as a warning, if you answer that dialog OK, MachProfile continues. If you want to print your Mach3 Settings, you have to use "Show Settings" in the Actions menu.
Klaus
Logged
Roy Smart
20
Re: Copy Config
Reply #15 on:
November 14, 2013, 10:36:35 AM »
Hi Klaus,
Many thanks for all your help, It is now working correctly and
I have the printouts required. I must have been making typo errors.
Thanks again
Best Regards
Roy
Logged
Print
Pages:
1
2
Go Up
« previous
next »
