Hello Guest it is October 31, 2026, 02:05:27 PM
Author Topic: objects not in the correct size  (Read 10163 times)
« on: November 01, 2013, 04:34:44 PM »
hi there,
i am new to this CNC stuff and i have question
in the detail of my machine  it say that the machine can engrave material in size of 275mm by 385mm ok so i open my coral draw program and make a new document by this size (275mm X 385mm ) which approximately 15inch by 10inch i draw in big letters
My
First
CNC (3 lines)
i save it in dxf (from the coral draw)  and convert it to g code (i use cut2d program)  when i am loading it to the mach3 i can see only the FI (front the FIRST) and the CN (from the CNC ) how can i set the engraving space to be larger so i can see all my drawing like it need to be ? is it the DPI from the coral draw? setting in mach3 please HELP me :) thank you
Re: objects not in the correct size
« Reply #1 on: November 01, 2013, 08:28:11 PM »
Demo mode is limited to 500 lines of g code. Is this your problem?
« Reply #2 on: November 02, 2013, 11:09:20 AM »
thank you  very much for your reply
and yes i think this is my problem when i got to about it show demo version
now i go to the mach3 website and purchase a license now what ?is the licence  file will be sent to my email ?
thank you
« Reply #3 on: November 02, 2013, 11:50:18 AM »
Yes it will come to you by email and you just save it to your Mach3 folder and when you open Mach you will be licensed.
I would recommend you also keep a backup of the licence in a safe place, although if you do lose it Scott will, I am sure, happily provide you with a duplicate as long as you can provide your info you gave whilst purchasing.
« Reply #4 on: November 02, 2013, 11:52:48 AM »
thank you for the reply
i purchase the license 1 hr ago how long i need to wait until ill receive it in the mail ?
Best Tnaya
