Hello Guest it is October 02, 2026, 10:46:44 AM
Author Topic: suppose to make around cut but is cutting an oval  (Read 7878 times)
« on: October 27, 2013, 05:28:42 AM »
Hi my name is Ivan and I tried for first time a small Gcode, it is a  small gear I have done it with a pen on a paper but instead a round gear the result was a oval gear.
I would like to know why.
regards
Ivan
Re: suppose to make around cut but is cutting an oval
« Reply #1 on: October 27, 2013, 06:38:08 AM »
Could be a few things, but it's hard to say without a picture. Make sure your steps/unit are set correctly for both axis. It sounds like one axis may be set incorrectly. But a picture would help if it's something else causing it.
