Hello Guest it is November 23, 2026, 12:32:12 PM
Author Topic: Steps Per Inch  (Read 9088 times)
Steps Per Inch
« on: February 27, 2007, 06:27:08 AM »
Hello,
My current cnc machine has a direct drive  20 degree tooth pinion and 20 degree rack setup.
My current stepper motors are 640 oz 1.8 degree 200 steps per inch.
So when I calibrate steps per inch in the settings page I wind up with somewhere around 639 steps per inch.
My machine cuts fine but the low resolution shows on circles and any radius I cut.
Is there anyway in Mach3 to increase the resolution (steps, a multiplier) or is the only solution mechanically such as a gear box or geared motor.
Thank you,
Tom
Offline nik
  •  69 69
Re: Steps Per Inch
« Reply #1 on: February 27, 2007, 06:40:42 AM »
this is the definition for resolution - step, pixel, point doesn't mater this is the minimum possible, if your mechanics have 639 steps per inch, this is your resolution, and one step = 1/639 inch, if you want to increase the resolution you have to gear the motor or use a motor with more steps, or micro stepping drive
i think last one is best, because stepper motor are sh...t , and micro stepping improve a lot their performance
