Hello Guest it is November 13, 2026, 05:55:05 PM
Author Topic: Pokeys 56U, M2 motherboard and M31 Keyboard matrix from cnc4pc problems  (Read 12182 times)
I have a Pokeys 56U connected to an M2 motherboard, attached is the M31 matrix keyboard from cnc4pc. I have not been able to get it to work. I am running the latest Mach3 software and the latest pokeys plugin.
I pokeys plugin I enabled the matrix keyboard settings and assigned the pins to the corresponding rows and columns. Then in the pokeys mapping I assign the matrix keyboard to press a button.
I have not been able to get this to work. Is there something that I am doing wrong? Can someone please give me a hand.
Remartinez
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys 56U, M2 motherboard and M31 Keyboard matrix from cnc4pc problems
« Reply #1 on: October 21, 2013, 10:15:30 AM »
Did you try the matrix keyboard in PoKeys application? Just close the Mach3, open PoKeys application and review the configuration of matrix keyboard. If all is done well, the keys should light up on presses in the Matrix keyboard configuration dialog.
