Hello Guest it is November 13, 2026, 05:19:36 PM
Author Topic: How to setup rotary encoder as MPG ?  (Read 25647 times)
« on: October 14, 2013, 10:11:18 PM »
Dear all.
PoKeys 56U, MACH3 plugin, all works like a charm.
Not using the PulseEngine, this runs via. 2x Parallel Ports
I have setup a rotary encoder on pins 1+2, and the encoder function works.
Have tried on different DROs
1) Where/How do I set it to control movement of the selected Axis (MPG mode)
Right now I can only select "Step" and "Cont." jog modes and not "MPG"
2) Is there a DoButton function that acts as the "Shift key" aka.  enable Rapid Jog override ?
Best Regards, Bo Andersen.
Offline NeoTO
  •  504 504
    • PoLabs
Re: How to setup rotary encoder as MPG ?
« Reply #1 on: October 17, 2013, 12:07:03 PM »
Hi, Bo
1. Go to Ports&Pins dialog and enable MPG1 under MPGs tab. Then map the encoder to the MPG1 DRO in the PoKeys plugin settings.
2. See OEM button 1903. This will toggle the jog mode. Rapid jog can not be mapped directly at the moment.
Matevž
« Reply #2 on: October 18, 2013, 12:32:07 AM »
Hi.
Great, I would never have guessed to enable the MPG, without setting some ports/pins also.
Anyway, it works.
Apparently I can set a keyboard shortcut Pin1 = "Shift" key, and this setting is kept when the MACH3 boots up with the PoKeys-MACH3 plugin.
I.e. I can enable the "Rapid Jog override" perhaps not in the best possible way, but it gets the job done.
Off-topic: Now where to find 100ppr encoderes ? Those on eBay is either those big, fancy and $$$ alu-wheels, or then they only have 20-24ppr ?
To be used for setting: Spindle speed, jog, speed, feed etc.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: October 19, 2013, 02:24:06 AM »
Hi, Bo
Do you mean these: http://www.poscope.com/index.php?route=product/category&path=61 PoMPG2 is a smaller version of PoMPG1.
Matevž
« Last Edit: October 19, 2013, 02:26:25 AM by NeoTO »
« Reply #4 on: October 23, 2013, 12:36:52 AM »
Hi Matevz.
No, I alreadu have the MPG as you link to.
It's more to control the Feed, Jog, Spindle, MPG-Jog speeds.
The "real" panels have 3-4 smaller knobs for adjusting the override of above speeds.
But I'm unsure if this is done via:
- Rotary encoders (grey-bit) Require 2 inputs, and rather precise in positioning.
- Pot meters ( 0-3.3V) Require only one input, but it "jumps" in the setting, and not easy to get back to precise 0% override.
- Rotary switch (1 pole, 12 posistions) This requires 12 inputs :-/
I was planning on using the Rotary encoder, but i can only find some with 20-24 ppr, which results in 5 turns to get 100% :-/
Any suggestions, perhaps there is a trick to get the analog one not to "jump" in voltage.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: October 26, 2013, 05:26:51 AM »
Hi, Bo
Analog filtering: use PoKeys software to enable analog filtering of the inputs
Encoder mapping: feedrate override should work fine with encoders.
Matevž
« Reply #6 on: October 26, 2013, 11:44:32 PM »
Hi Matevz.
Thanks again.
Will look into the Analogue filtering, alternative the Encoder :-)
Lots of new possibilities and features with PoKeys....
