Hello Guest it is November 13, 2026, 04:17:10 PM
Author Topic: Edit Script Ref All Home  (Read 11244 times)
« on: October 12, 2013, 08:07:20 AM »
Hi. I'm trying to use the "Ref All Home" in Mach3 but I can not get results. When I edit the script button I have this:
DoButton (24)
DoButton (23)
DoButton (22)
The problem is that when I press the button once I saved changes and rebooted Mach3 script, the three boxes of DRO are illuminated in green, but the machine does not move until the limit switches.
What I want is that Mach3 references first the X axis to the limit and then go back home X amount (about 1/2 inch) to disable the limit switch (and reset X DRO to zero), then do the same for the Y axis and finally in the Z
Can anyone help me?
Thank you very much to everyone in advance.
Re: Edit Script Ref All Home
« Reply #1 on: October 12, 2013, 10:35:52 AM »
Is sounds like you don't have your Home switches enabled in Ports and Pins.
« Reply #2 on: October 12, 2013, 10:44:17 AM »
Right now I just get that with individual buttons referencing each axis machine. Now, what can I do to make the button "Ref All Home" do what I suggest in the post?
